Flexplate & starter
Old Apr 3, 2009 | 09:38 AM
Larry Woodfin's Avatar
Default Flexplate & starter
Please bring me up-to-speed about the GM flexplate adapter. [part number of spacer & bolts] So that a powerglide and SFI flexplate can be installed.
Also, what is being used in reference to starters? Is the Delco starter capable of starting a 12.1 compression 370 CI [4.030 x 3.622] or, is an aftermarket starter a better choice?
Old Apr 3, 2009 | 10:23 PM
DrkPhx's Avatar
You'lle get a better response by posting in the Automatic Transmission section. Maybe contact FLT as well. They build transmissions.
Old Apr 8, 2009 | 09:24 AM
1lejohn's Avatar
Power Masters has a nice starter that is clockable so that it can fit different header combos. TCI makes a flex plate and spacer for older style trannies, I'm not sure about a power glide.
Old Apr 8, 2009 | 01:12 PM
Project GatTagO's Avatar
I also believe that some converter manufacturers are making converters for older transmission that eliminate the need for an adapter and have the proper bolt patter for the LS flexplate.
Andrew
