Ls7 in f body
Old Apr 17, 2009 | 06:30 PM
ms4z28's Avatar
Default Ls7 in f body
I am thinking about this in my 2000 z28 and do I need to convert to the ls2 parts like the front cover and censors or is it possible to do with all the ls1 stuff and what all do I need to convert if I have to?
Thanks...
Old Apr 17, 2009 | 07:14 PM
blu byu EH's Avatar
the thing that you need is the ls2 conversion kit it comes compete with everything that you need.
Old Apr 17, 2009 | 08:00 PM
the_merv's Avatar
Veteran: Air Force
Depends on also if you want to run it as a Dry Sump or a Wet Sump setup..
I was looking into a LS7 for my Car at one point, it wasn't hard to make it a standard Wet Sump.
Old Apr 18, 2009 | 03:22 AM
ms4z28's Avatar
ok thanks but really im not sure on the dry sump or wet is... its to make sure the oil stays where its supposed to be right and what would be better cuz im hoping to try to make atl east 650 on motor maybe more that would be cool... and is it easier to do the ls2 conversion or try to keep the ls1 stuff.... and also i want a 200-250 whp shot at it
Old Apr 18, 2009 | 04:23 AM
PUNISHER TA's Avatar
$30,000...
Old Apr 18, 2009 | 05:17 PM
blu byu EH's Avatar
The only thing that you can used from the ls1 is the knock sensors and the oil pressure sensor. You have to used the ls2 conversion kit in order for the ls7 to work in the camaro.
Old Apr 20, 2009 | 09:53 AM
ms4z28's Avatar
Okay thanks for the help
