Dbw throttle body
Old Apr 25, 2009 | 06:09 PM
Encore's Avatar
Default Dbw throttle body
Does anyone know if the dbw tb on the l76/l92 is the same as on the ls2 & ls3?
Old Apr 25, 2009 | 09:42 PM
scatillac's Avatar
Default 90mm DBW
Visually they appear the same although I haven't checked part numbers, but I'm speaking of an LS2-equipped V.
I'm using the 90mm from an L76 on my LS7 and it works just fine.
Old Apr 26, 2009 | 06:15 PM
See5's Avatar
Yes, the LS2,3,7, L76 are interchangeable.
Old Apr 28, 2009 | 01:26 PM
Project GatTagO's Avatar
A stock L92 throttle body is different. They bolt up to the same flange as the LS2/3/7 throttle bodies, but they are designed for a truck.
Andrew
Old Apr 28, 2009 | 01:32 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
There is also a new style TB for the brand new LS7s and the LS3s...
barely came out
Old Apr 28, 2009 | 01:35 PM
barely came out
Pictures?
Andrew
Beau@SDPC's Avatar
LS1Tech Sponsor
heh...if i had pics i would post them. hopefully we can have them up soon.
Old Apr 28, 2009 | 02:07 PM
See5's Avatar
If it is this one (top) they are the 09 version for LS3/7 and are not backwards compatible>
#12605109
Old Apr 28, 2009 | 02:10 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
correct, not backwards compatible...
