Underdrive Pulley
the one for the fbody will be kpbu1480ss25 for the 25% ud kit.
i have seen very good dyno results using this setup, and really no adverse problems from installing it unless you have an abnormally high elec demand on the car
If not, go for it. It's not a seat-of-the-pants difference, but every little bit adds up. I never had any cooling issues, and the only time the voltage dipped was at idle surges (big cam/heads/m6 car)
Also, keep in mind that if you have an M6 and/or plan on putting a stroker in there, harmonics become an issue. At that point, a high end damper (ATI, etc) makes much more sense.
