LS1 to LS2 F-Body converts
Old May 13, 2009 | 07:00 PM
JFM-jr's Avatar
Default LS1 to LS2 F-Body converts
Will I have an issue with the LS1 oil pressure sending unit mounted in the LS2 valley cover? Wondering if it will fit under the cowl . Motor is on the stand and seems like the sender will now sit higher than it did in the LS1. Thanks
Old May 16, 2009 | 08:27 PM
fbam's Avatar
I did an ls1 l92 swap and i had to use the ls1 sending unit because of the wiring. It did sit up higher but it wasnt a problem and worked just fine.
Old May 16, 2009 | 10:07 PM
rpmauto's Avatar
mine works fine, no issues stock replacement
Old May 17, 2009 | 01:14 AM
JFM-jr's Avatar
Thanks guys.
Old May 18, 2009 | 01:05 PM
PlatnumStatuz's Avatar
not a problem
