LS3 2Bar MAP Sensor
Old May 20, 2009 | 09:59 PM
TYRFRYR's Avatar
Default LS3 2Bar MAP Sensor
I'm trying to find a part number (if it exists) for a LS3 MAP sensor replacement (Stock Part Number 12591290) that supports boosted applications and will fit into the factory manifold and connect to the factory harness.
The BOSCH Part Number for the OEM LS3 MAP Sensor is 0 261 230 146. I'm sure BOSCH makes multiple measurement ranges in this sensor family, now to just find them?????
Old May 20, 2009 | 10:28 PM
SweetS10V8's Avatar
Id try to see if the LSA or LS9 Map sensor will work in your application since they are both boosted from the factory.
Most MAPs are swappable without any work, and worst case you have to change two pins to make it work.
Old May 20, 2009 | 10:48 PM
TYRFRYR's Avatar
Anybody have the GM Part Numbers for these???
Any Pictures???
Old May 21, 2009 | 11:42 AM
sroach20's Avatar
http://www.bosch.com.au/content/lang...cification.pdf
page 34
Old May 21, 2009 | 03:36 PM
Big_Bird_WS6's Avatar
and what is good to use if you move your map sensor?
Old May 21, 2009 | 07:36 PM
TYRFRYR's Avatar
Originally Posted by sroach20
Yep. Already have that tech spec. Know where I can order one??
Old May 21, 2009 | 07:40 PM
SweetS10V8's Avatar
Scoggin Dickey
Old May 21, 2009 | 08:02 PM
sroach20's Avatar
best bet is to call bosch, otherwise you will have to ship from overseas. the opal, fiat, and some other turbo diesels use them.
Old May 21, 2009 | 08:07 PM
sroach20's Avatar
http://translate.google.com/translat...%3Den%26sa%3DG
Old Jun 26, 2009 | 08:05 PM
TYRFRYR's Avatar
We'll I've managed to figure out why it's so difficult to get the right part number for this.
This is an excerpt from my thread on HPTuners.
Originally Posted by JakesG8
They are listing #12591290 as spchg air inl presure #12592525 is spchg air otlt press.From the pic in the catalog both are retained by a screw. Dont know if that helps
Thanks man!!
I think I discovered why this has been such a challenge to find the right part number.
I managed to talk a local dealer into letting me look under the hood. Popped the cowl up and found two BOSCH Pressure Sensors (#1 and #3). At the time, I didn't realize that there were actually 3 pressure sensors on this engine.
Both sensors (#1 and #3) had the same part number (12591290). Both were BOSCH sensors. Both had the same BOSCH Part Number (0 261 230 146). #3 was made in Mexico. #1 was made in Germany.
I just ordered Part#12592525 noted from the post above. I'm hoping it's the #2 sensor. We'll see if it's the right one.
Wish me luck.
Old Jun 26, 2009 | 08:10 PM
Petraszewsky's Avatar
I need a stock LS3 map sensor and can't find a thing with the stock part number you listed...Do you have any other info on the stock one?
Old Jun 26, 2009 | 08:28 PM
TYRFRYR's Avatar
Check Your PM.
Old Jul 5, 2009 | 12:04 PM
Rocket468's Avatar
You can also get a 2 bar off the grand prix, and the cobalts ss that are supercharged if you get the one on top. The one after the supercharger is a 2.5 bar.
Old Jul 8, 2009 | 05:06 PM
TYRFRYR's Avatar
Here is the 3Bar Bosch Style MAP sensor for the LS3/L76 Style Intake Manifold. Part Number 12592525.
Thanks to RWTD for the Calibration Data.
Linear: 312.50
Offset: -11.25
Old Jul 8, 2009 | 05:09 PM
Awesome...Could you post the MAF table? and how much are those new?? Probably about $90??? Same connector and everything?
Old Jul 8, 2009 | 05:18 PM
TYRFRYR's Avatar
Slips right in. Bolts right in. Plugs right in. Took 5 minutes including the ecm recalibration.
$24 plus shipping. Total was around $35.
Old Jul 8, 2009 | 05:22 PM
Cool...Before you sold me that LS3 MAP I went to the stealership and they told they wanted $90...I'll be bookmarking this incase I decide for boost!!! Oh and those tables???
Old Sep 1, 2009 | 06:53 AM
boyley's Avatar
is this still running ok had no issues at all? Would you not lose some resolution if only utilising 2/3rds of the range
Old Sep 1, 2009 | 12:51 PM
TYRFRYR's Avatar
It's working fine.
Old Sep 2, 2009 | 11:40 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
where did you buy it from?
