What is the 241 and 243 head?
Old May 27, 2009 | 03:59 PM
TransAm's Avatar
Default What is the 241 and 243 head?
Are these the ls2 and ls3 heads?
Old May 27, 2009 | 04:01 PM
z28hustle's Avatar
you should do a search and read up
Old May 27, 2009 | 04:11 PM
MMMZ/28's Avatar
Just answer the question....
241 heads were stock on ls1 camaro's past 99 I think 98's had 853's
243 heads were stock on a LS6 which was in the C5Z06.
Old May 27, 2009 | 04:16 PM
TransAm's Avatar
Thanks
Old May 27, 2009 | 06:05 PM
VIPRETR2's Avatar
If you're going to answer it, at least get it right.
'97-'98 have 806 castings and perimeter bolt valve covers.
'99 through early '00 LS1s got 853 castings.
late '00-up LS1s got 241 casting heads.
LS6 and LS2 motors (as well as alot of other motors) got 243 heads. All of these are identical except the '01-'04 Z06 LS6 motors got 243 castings with lighter hollow intake and sodium filled exhaust valves and command a premium on price while the other motors got stuck with regular steel valves. The 799 casting is identical to the non LS6 243 head as well. All of this info was readily available with a search (which I did to verify my info). Can't help you with the LS3 casting numbers. Good luck,
Larry
Old May 27, 2009 | 06:15 PM
Bouvs's Avatar
good info there... clarified a few of my own curiousities...
Old May 27, 2009 | 06:29 PM
z28hustle's Avatar
Larry
which was completed with a search!!
Old May 27, 2009 | 07:03 PM
Mgpeagle's Avatar
Just an FYI. Monte Carlo SS (06-08), Impala SS (06-08), and Grand Prix GXP's (05-08) have 243 casting heads also. These cars have the LS4 engines.
-Mike
Old Jun 1, 2009 | 08:46 AM
fourpointsix's Avatar
06 TB SS LS2 = 243 heads also?
Old Jun 1, 2009 | 10:55 AM
RickClarke23's Avatar
Yes Some TBSS have 243 heads or the other Variance of the 243
Old Jun 3, 2009 | 09:49 PM
Engine_HP's Avatar
241 came on late 2000 ls1
243 came on ls2 & ls6
