LS6 Oil Pump and Thermostat Question...
Old Jun 5, 2009 | 11:26 AM
JoshuaCole67's Avatar
Default LS6 Oil Pump and Thermostat Question...
i have done some searching and i found alot on LS6 oil pumps ported and non ported! But they normally have some sort of forced induction or a huge cubic inch or cammed... I have a practically stock LS1 with an LS6 intake and full exhaust... My oil pump is startin to take a poop on me and i am lookin to get another one and figured i might as well get an LS6... good idea? what are the advantages with my engine...
My other question if for a thermostat... i want a 160 degree therm cuz its the smallest i have seen... but a friend told me if i get it i have to get my car tuned so my car will recognize it and run cooler? True.. or can i just kinda plug n play...?
Old Jun 5, 2009 | 07:35 PM
coco95z28's Avatar
the thermostate will work just fine. AS LONG AS THE CAR IS MOVING...
you should reprogram your fans or get a manual fan switch to kick them on sooner... but you dont have too.
BTW, dont you think the 160* is a little too cool?
Old Jun 5, 2009 | 07:40 PM
405HP_Z06's Avatar
1. stick with the stock thermostat
2. The 'LS6' pump is the stock replacement part for the LS1 from GM
Old Jun 6, 2009 | 01:26 PM
IDK anything about thermostats.. is it too cool?
So it would be a good idea to upgrade to an ls6
Old Jun 6, 2009 | 10:12 PM
405HP_Z06's Avatar
That is the current GM stock replacement pump, so you don't have a choice unless you go aftermarket.
