tryin to prep for intake swap
Old Jun 29, 2009 | 05:35 PM
jts98z28's Avatar
Default tryin to prep for intake swap
i bought a bbk ssi intake and a professional products tb and intake gaskets with the foam...what else do i need to do my swap? thanks
Old Jun 29, 2009 | 07:44 PM
LS1MCSS's Avatar
Be very careful removing your old intake or you will need a new oil pressure sender.
Old Jun 29, 2009 | 08:39 PM
tektrans's Avatar
bbk?
you'll likely need a tune. Your in south jersey, Cartek is exit 137 off the GSP.
Old Jun 30, 2009 | 10:42 AM
jts98z28's Avatar
is there any tips u have on making this easier or what to look out for
Old Jul 2, 2009 | 04:51 AM
LS1MCSS's Avatar
The big vacuum line to your power brakes runs behind the oil pressure sender. If you try pulling the intake forward very much at all, you'll break the sender. The top section of it is plastic and breaks real easy. Use a small mirror and look behind the intake and you'll see what I mean.
Old Jul 2, 2009 | 09:28 AM
jts98z28's Avatar
thanks
Old Jul 2, 2009 | 09:41 AM
deelong4002's Avatar
Be prepared to cut the **** out of your hands! THere was no way i could wear gloves cause you need to feel everything on the back.
I'm not sure if you need this or not, but on an LS6 swap or FAST you need the coolant block offs on the back, and the cross over tube for the front and also button head screws for the valley cover.
Other than that, it is pretty straight forward. I had a hell of a time getting the electrical connectors for the fuel injectors off. I would say i spent more time doing that, than i did actually removing the intake!
