Confirmed GMPP LS7 fuel rails
The question was, what fuel rails will bolt on to a GMPP LS7 single plane efi intake (part number 25534413)??? No one could give me the answer I wanted. Most said they just did custom rails with welded brackets.
I wanted a bolt on part, for a clean look. So I did not have to weld brackets on the runners like I did with my L92 GMPP.
So with some help from Nineball (thanks Tony!), he sent me the stock LS7 rail assembly from his 09 ZO6. I was able to fit the injectors, and all the bolt holes lined up perfectly.
I will order Aeromotive LS7 rails, they come with lower injector o-rings, and taller brackets to work with the bosch style injectors I have.
Bolt on deal, anodized red, and capable of 3000 hp.
http://www.aeromotiveinc.com/products.php?prod=263
So, for anyone crossing this road, the aftermarket LS7 rails will work with proper spacers and orings on the GMPP LS7 EFI single plane.
