Would 90mm FAST intake cause problem on 427?
Old Jul 27, 2009 | 05:14 PM
grb's Avatar
grb
Question Would 90mm FAST intake cause problem on 427?
Title says it all. I've been told the 90mm FAST causes problems on a 427.
Old Jul 27, 2009 | 07:21 PM
tektrans's Avatar
Never heard of any issues, kind of a broad question. Solid roller 427 yeah I could see the Fast being an issue just because of the long runners but for a hydraulic stroker should work well if it's done right.
Old Jul 27, 2009 | 08:19 PM
grb's Avatar
grb
I am planning on a solid roller and possibly a ProCharger.
Old Jul 27, 2009 | 08:33 PM
HUNTER02SS's Avatar
I thought your new Warhawk motor was completed already?? I seen the article in GM Hi-tech. I think it was also close to 500ci. Maybe a different motor?
Old Jul 27, 2009 | 09:05 PM
grb's Avatar
grb
Yeah. Different. Warhawk 496, C5R 427.
Old Jul 27, 2009 | 11:25 PM
BAD2000TA's Avatar
Are you talking LS7 - then no; intake ports are different. Standard head/intake ports - no problem.
Old Jul 28, 2009 | 06:48 AM
tektrans's Avatar
I wouldn't get the fast if you're doing a solid roller. Single plane intake would be a better choice.
