oil pressure sensor ls3 in a 4th gen
Old Aug 14, 2009 | 09:42 PM
ls1crazy326's Avatar
Default oil pressure sensor ls3 in a 4th gen
I have a new ls3 motor in my 1999 camaro and was told I need to use a ls2 style oil pressure sensor because it is shorter than the ls1 style the only problem is that the connectors do not match. I am wondering if i can just use the ls1 style sensor since it works with my harness but I am not sure if it will fit right do to its taller height. also like many other people I am still waiting for the new LSXR intake to come out to see if it will clear
Old Aug 16, 2009 | 01:09 PM
Ramairbird's Avatar
I run the stock ls1 sensor in my set up see sig.
Old Aug 19, 2009 | 04:28 PM
99TransAmLS16Spd's Avatar
I reused my ls1 oil sensor as well. It sits higher, but the brake booster hose situation is no different thatn stock - just use care when removing and installing the hose so you don't break the sensor
