GTO, Maggie- o2 sensor going bad!?
Old Aug 16, 2009 | 11:21 AM
Eagle Performance's Avatar
Default GTO, Maggie- o2 sensor going bad!?
One of my customers has an '05 GTO, mild cam, exhaust, Magnuson S/C. Had an 02, (Bank 2, Sensor 1) go bad, it was replaced. Called me, same symptoms, cel, plugged the scanner in, same issue. Any one had constant bad o2 sensors? I know one of the sensors has crimp on connections, he is going to check which one it is, I'm wondering if the connections are causing this?
