Removing pulley from LQ4
Old Aug 23, 2009 | 01:51 PM
Justus67's Avatar
Default Removing pulley from LQ4
I'm using a 3 jaw puller to remove the pulley from the front of the motor, are there any clips i need to remove or bolts I can't see that would stop it from coming out? I'm putting a bolt in the hole and tightening down on that, any tips would be greatly appreciated.
Old Aug 23, 2009 | 10:03 PM
SchuttsR1's Avatar
Your doing it right. Just put the jaws around the pulley and put a bushing or washer in the middle of the pushing rod and crank.
Old Aug 24, 2009 | 09:19 PM
00HARDZ28's Avatar
I would use that three way and maybe a socket that fit the crank size so you dont have to worry bout screwin the threads up. good luck to ya
I would use a impact socket type there usually black socket
Old Aug 24, 2009 | 10:01 PM
Jeff Smith's Avatar
I just pull that LQ4 crankshaft pulley out. I use the tool loan (crankshaft pulley and harmonic balancer puller & installer set) from Advance Auto Parts.
If you can't solve with that, I ll post pixes...
Old Aug 25, 2009 | 06:23 PM
the jester 812's Avatar
i just removed one about a week ago, i had to use a impact gun with over 500/torque and it slid right off after about 20 seconds of hammering.
