95mm TB with L76 intake?
Old Aug 31, 2009 | 02:50 AM
BLOWN SS/T's Avatar
Default 95mm TB with L76 intake?
Doing an l92/ls3 swap into my 98 fbody
I just ordered the L76 intake with rails and injectors, and Im going to need a 90mm TB. I was looking at the jantzer 95mm TB, but was wondering if this would work with the l76 intake. Or if I could use a 92mm fast TB, or does it have to be a 90mm due to the opening on the l76 intake.
I'll also be needing a TB cable bracket for the l76, I know SLP sells a bracket. But Im trying to see if anyone has made anything, and if they have any pictures.
Thanks
Old Aug 31, 2009 | 12:28 PM
RyanSws6's Avatar
I just did a LS3 top swap. I've got a 90, but I got the int ported. A biger TB will fit.
Old Aug 31, 2009 | 02:01 PM
BLOWN SS/T's Avatar
It'll fit but its going to be restricted right? Can you port a l76 intake? And if I just slap the 95mm on a stock l76 intake will there be any other problems, or does anyone not recommend it?
Old Sep 1, 2009 | 04:58 PM
davidws6's Avatar
Default 95mm
I'm sure there's enough meat you could remove to get a 95mm TB to fit. That's only 2.5mm round the opening. = + - 1/16 of an inch...
Old Sep 6, 2009 | 09:02 PM
Gen414's Avatar
If in need of a 90MM or 92MM TB, I have 'em on sale, right here....
http://www.morrismotorsports.net/for...ducts_for_sale
Any questions, let me know.
Thanks
