vacume leak around injectors help
Old Sep 17, 2009 | 10:02 AM
smokin91rs's Avatar
Default vacume leak around injectors help
i have a 99 c5 and swapped a ls3 in with heads and cam. im using my old 42lbs delphi or bocsh forget what they are "tall" injectors, im using the lingenfelter swap o-rings but no matter what i do i have half or more ofthe injectors sucking in carb cleaner. any body else have these problems?. i have stock ls3 injectors anybody know what hp level they are good for i think they are ?32lbs?. i will get injector pigtails and swap them. if they are big enough.
-im running prc cnc l92's with a gx6x3 500-520rwhp
