intake question
im running a 4x4 p/u single cab with a 6.0, heads, cam, full bolt on's with a circle D converter and a n2o outlet plate kit with a 150 shot please help me out guys thanks............
The vic jr is also a high rpm single plane manifold designed for high rpm, typically at the cost of bottom and mid range. They are especially bad when you put an elbow on them.
I would run a plastic intake manifold myself, but not the LS2!! Its almost the worst plastic intake there is. I ran the LS2 intake for a while and swapped to a FAST 92mm and gained 21rwhp and it was acrosss the board, not just on the top end. You could really feel it!!!
I would personally wait for the FAST 102mm LSXRT Truck intake! Its supposed to be coming out within a month.
07z71 i would buy a used 90/90 for your set up for around 800$
YES!! The smile it put on my face the first time I hit the gas the first time I tried it out affrimed it was worth it.
Its not all about one peak number, I gained accross the board, and could really feel it. It was amazing. And all these "ported" intakes, are done by humans who make some good, some not so good. Thier repeatability is low.
Jeremy F @ Fasterproms ported an LSXR. Before porting it was 15hp and 16lbft over the stock LS3, and after porting it was worse than stock!! It lost the entire 15hp 16lbft gain and then some.
lol what did he do port right through the thing? That's nuts that it lost that much hp from porting. Not saying its not true, just saying thats crazy and I wonder where it went wrong.
The LSX intake (78/90/92mm) all had a large bump at the end of the runner. People basically ported that out to make the power difference everyone has been seeing for years.
When I got my LSXR, I closely looked at the runners and that bump is gone. I think FAST figured that out and fixed it on this new generation of intakes myself.
Manifolds are just like heads, "porting" isn't always a good thing, unless your bench racing or talking a big game on the forum. Many people really screw things up trying to port and dont do a good job, or they over port, both which can cause loss in flow. Even worse it can cause the air to become turbulent and separates! This leads to vorticies and chaos in the runner which results in loss of power!
