So No One Has?
Old Nov 18, 2009 | 06:53 AM
BRD-PREY's Avatar
Default So No One Has?
put a 06 GTO starter on an LS1/LS3 if an F-Body??
Just want to make sure before I drop the coin had heard that the 06 GTO starter has more torque.
ED
Old Nov 18, 2009 | 08:18 AM
Caveman's Avatar
10 & 11 Second Club
Why dont you just get a Power Master starter, much better then stock oem ,more torque and probably cheaper. You can get them from Jegs or Summit.
Old Nov 19, 2009 | 05:29 AM
BRD-PREY's Avatar
the info I've received from a buddy that has lots of LS experience is the stock starter is fine and the Mitsubishi part# for the later year GTO is even better, higher torque geared down slightly. The best part is it brand new with 1 year warrantee $119.00. The GM price for this specific part number is like $437.00 with online GM parts dealers selling it for $305.00.
So, it seems like the way to go. If some wierd issue pops up I will post it here but I don't foresee it.
P.S. I don't cut corners on parts, so if this direction didn't feel right I was going to buy the Permanent Magnet TCI starter. The thing is the gear ratios are so high on those aftermarket starters for crazy ( read I guess ethanol/alcohol) compression ratios 18:1 ratings that I wasn't sure if I wanted it to turn that slow on a daily driver.
Ed
PS your car looks good
Old May 19, 2010 | 07:47 AM
sjsingle1's Avatar
i got the MSD starter......cranks it right up.......and sounds like a F-16 when it spools
