I need help please!!! All info considered
Old Dec 27, 2009 | 07:11 PM
nitrobusa's Avatar
Default I need help please!!! All info considered
I'm having some electrical problems and don't know what else it could be. First off let me tell you what it's doing. When you make a left turn from a slow speed or stop the car dies. We have been tuning the car and it's killing fuel to the car and the wideband goes to 21*. I have checked the connections to the fuel system and none of them is in a bind. I have replaced the wire from the alternator to the battery. Checked the fuel lines. Made sure the car has a ful tank of gas and replaced the crank position sensor. (I did a search earlier and that's what someone else said). I also put a constant ground from the battery to the block and it's still doing the same thing. I'm totally confused and do not know what else to check.
Old Dec 27, 2009 | 07:53 PM
G Engines's Avatar
It could be the pump has come loose it the tank and moving around and pulling on the plug when you turn left. Your wide band is going to 21 because your loss of fuel is leaning you engine out. If it was an ignition problem your wide band should go rich and the engine would flood out.
Old Dec 27, 2009 | 08:40 PM
nitrobusa's Avatar
I don't have a in tank pump I have a Bosch 330 external pump with -10 feed lines and -8 return. What do you think about the body control module?
