Help designing air pan for 427c5r???
A better option would be to fit a standard circular aircleaner to the throttlebody and build a circular tub around it, and use neoprene foam to seal the tub to the hood. You'll have to remove the support brace in the hood to make that work.
As for an aircleaner.. I think you might be stuck there. You'll have to hack a TON of the hood out to get that to work I think...
Makes me wonder how close that intake is gonna be to a 5 inch sloped ws6 hood...
I like what you did with the IAC, that's prety cool too by the way.
