VVT Install Questions
Old Dec 31, 2009 | 10:40 AM
TrueBlueGTO's Avatar
Exclamation VVT Install Questions
Three questions:
1) Can VVT be installed along with a DoD?
2) What are all the parts necessary to install a VVT system in a LSX
3) Once installed can it be locked in a certain phase via tune?
Thanks in advance!
Old Dec 31, 2009 | 05:40 PM
Jimbo1367's Avatar
I am pretty sure the VVT varies throughout the RPM and load. You would be defeating the VVT if you locked it into a set"phase" as you call it. Just my .02
Old Jan 1, 2010 | 06:33 AM
SweetS10V8's Avatar
YES
Things like the phaser, timing cover, PCM, harness, etc
Yes, you can lock it anywhere you want, but that would be giving you less power than the VVT gives you potential for.
Youll need pistons with valve notches too.
Old Jan 2, 2010 | 05:38 PM
LS1 TJ's Avatar
Default VVT parts
I have the VVT timing cover, cam gear, cam and water pump from a 2009 6.2 Denali if you are interested.
PM me.
Jim
Old Jan 12, 2010 | 05:36 AM
Question
Originally Posted by SweetS10V8
YES
Hmmmm...what if I went Gen IV? Does the LS2/L76 have notched pistons?
PM me.
Jim
PM sent...what are all the parts needed to convert?
Old Jan 12, 2010 | 07:45 AM
Also, does anyone know the total degree range of advance/retard timing for the the VVT system?
Old Jan 17, 2010 | 09:01 PM
Bo185's Avatar
The phaser can turn the camshaft over a range of 31 degrees relative to the cam sprocket (or 17 degrees advance, 45 degrees retard relative to the crank).
Old Jan 17, 2010 | 09:49 PM
SweetS10V8's Avatar
The phaser does not advance the cam at all, it retards it. The 2007-2008 engines have more range than the 2009+ phasers.
2007-2008s have a range of motion of something like 60+degrees crank (30+ cam) of retard.
2009+ has something like 54 degrees of crank retard.
Old Jan 27, 2010 | 11:29 AM
mark underwood's Avatar
You also need the vvt oil pump..
I also have all this from my swap for 50$$ cover, cam gear/bolt, oilpump.
