upgrade maf on 402
Old Jan 5, 2010 | 10:52 AM
35th camaro's Avatar
Default upgrade maf on 402
have 2002 camaro inst. 402 with my ls6 intake , ported tb, what do you think about upgrading my maf, stock looks pretty restrictive for a 402, i would get it tuned when put on (actualy would drive to dyno on stock maf and put other once there) any sugestion on size and brand.
Old Jan 5, 2010 | 10:58 AM
t/a98's Avatar
why not replace your ls6 with a fast92/92? seems like thats your biggest restriction.. stock maf is fine past 500 horses, are you surpasing that?
Old Jan 5, 2010 | 07:00 PM
i think should be in the450- 475 range,patriot stage3 heads, 236-242 duration, 650 lift with my gold roller rokers 1.85, pacesetter cer. headers and off road y and loudmouth, racetronix fuel pump, 42lb inj, not going with fast(price) at least not this year. slp lide, holley air filter, smooth below, ported tb , just looking at maf and that big alum. bar going across the center seems to not leave mutch room for air. what maf do you guys get a good perf. from.
Old Jan 5, 2010 | 07:35 PM
69LT1Bird's Avatar
The 85mm truck MAF would be all you would need.
Old Jan 6, 2010 | 04:42 PM
85 mm truck, what year and engine size had the 85mm maf? what size is my original?
Old Jan 6, 2010 | 04:51 PM
69LT1Bird's Avatar
Stock you are either 75 or 78mm.
Here is a good list:
85mm MAF
