Why oil in the intake air charge is BAD...
GM in their design accepts oil in the intake, but there is nothing good that comes w/it.
1. You want only air & fuel in the combustion chamber, oil does not burn well and any oil included in the intake air charge will result in less energy released per explosion, and it also reduces the useable octane of the fuel your using....resulting in detonation and less power & less fuel economy.
2. The oil does not burn completely and leaves a deposit that builds up on your piston tops & valves. This causes the burn to be uneven & results in hot-spots on the piston top, and the deposits on the valves reduces the velocity, or volumetric efficiency again negatively affecting power.
3. The carbon buildup left by the oil is a very hard & abrasive compound that as small pieces break off can be caught between the cyl wall & piston causing score marks and shortened engine life.
So no!!! Nothing good comes from oil in the intake, but to meet emission requirements GM & every other manufacturer of engines accepts it as a side effect of a closed crankcase ventilation system. A good, proper working oil separating catch can is the only good solution.
