Electric water pump power supply
Old Jan 7, 2010 | 06:13 PM
RsSean's Avatar
Default Electric water pump power supply
I am literaly in the process of putting on my Meizer electric water pump. Was wondering where you guys are pulling the power from?
Pic would be best
Thanks
Old Jan 7, 2010 | 07:30 PM
Jontall's Avatar
Have to use their relay and pull power right from the battery.
Old Jan 7, 2010 | 09:05 PM
2000_SS's Avatar
ls1howto.com has a great write-up for installing a Meziere pump on a F-body.
They use a relay with power from the (+) terminal on the fuse box with a 12v switched source coming from the large pink fuel pump wire under the fuse box
Old Jan 8, 2010 | 01:36 AM
99Bluz28's Avatar
I did the same except I went and connected my water-pump relay turn-on wire to the gray wire coming out of the fuel pump relay on my 99 Z28.
Old Jan 8, 2010 | 08:07 AM
RsSean's Avatar
Well WTF mine did not come wioth said relay. This horse hockey. Well I guess I am just going to fuse it and go to the fuel pump.
Old Jan 8, 2010 | 06:59 PM
2000_SS's Avatar
go to ls1howto.com....they list the part number for a borg warner relay you can get at any parts store.
Old Jan 8, 2010 | 09:47 PM
shoemike's Avatar
I plugged mine into one of the headlamp door slots (camaro)
