LSX block Knock sensor pictures please
Old Jan 13, 2010 | 12:23 PM
Mike75356's Avatar
Default LSX block Knock sensor pictures please
Anyone have some pics of how these are mounted on the block also if you have any pics of the cam sensor mounted i would like to see that as well. Getting ready to mount my knock sensors and was wonder if you guys used the bolt bosses on the side of the block or taped your own or what??
Thanks in advance for the pictures and help
Old Jan 13, 2010 | 01:11 PM
plumcrazy1's Avatar
I used existing threaded holes in the side of the block for mine and it worked fine. Cam sensor is mounted on the front cover had to go to a ls2 style cover and by a harness to make it work. Got that from Texas Speed... Hope this helps
Old Jan 13, 2010 | 02:19 PM
Mike75356's Avatar
Thanks, yea i got the extension harness and what not. Just was hoping to get some pics of the knock sensors actually mounted and put in so i can get a better idea of how exactly they should be
Old Jan 13, 2010 | 09:39 PM
InsaneDomestics's Avatar
This Isn't An LSX Block But The Location Of The Knock Sensors Should Be The Same.
