6.0+ liter 600HP+ before the jug????
It can be done but it isnt cheap. Solid roller hi rpm deal.Its much much easier to up the cubic inches. We're talking at the wheels right?
I have a fully built & forged 408 CID from Brian at Late Model Engines in texas. The motor has a stock L76 intake, Ported 92mmTB, 65lbz. Fast Injectors, TexasSpeed Ls3 heads flowing 358CFM @ 650' Lift milled to 68cc, 11:5:1 compression, CamSpecs 251/259 660/664 LSA-111, 1-7/8 Hooker LT's, TexasSpeed 3" True Duals, Moser 12-Bolt 4:10's, Eaton Locker, STG 3 M6.
The car made 527/475 on motor with a speed density tune. I haven't got anything else yet for the car. it runs hard from 4000RPM and up... Anything under 2500 it does not like. Obviously... lol I can tell at 3000RPM it detinates not very badly, but enough that i can tell it has alot more left in it. Not to mention the car idols alot at 2000RPM. When it idols down it sits at about 1250 or so... Not sure if the tuner should have been in my car. I think personally not that i'm trying to get a puffy chest and brag about a motor, but for the power it made i wasn't impressed being that i see cars on here all day and everywhere else making 550+ M6 and 530+ Auto... So i am not quite sure what is going on. Any suggestions would be awesome cuz i'm planning on running alot of junk this summer so i'm trying to find out which components aren't matched besides the intake like everyone else foreal lol My heart is set on a desired range of 3500 to 7500, victor junior single plane plumbed for a fogger set-up, 4500 wilson TB, and 373 gears so i don't shift out of fourth gear on the street so i can stay in my power band longer. Driveabilty isn't **** if you can drive a M6 with a 660' lift camshaft.... lol it's a bitch to drive only making poor numbers IMO...
The super victor intake would be a better choice, the heads you have on the car aren't bad, not the best choice for what you want to do but for the $ they aren't a bad head, I think the 245 tfs larger cc cathedral heads from PI (used to be ET), or the newer ls7 port heads from PI would certainly give you a better chance. Allpro also makes a very good piece that should be considered an option. The camshaft should be fine, not sure what the low lift #"s look like but I'm sure it will work.
I would recommend a head swap and get the compression up to about 13.5 to 1, along with the intake change, spend the $ on getting a super victor ported, or if you can get one and have the $ the PI single plane will certainly serve your purposes as well. You can kiss running pump gas away, but if you want the power it shouldn't matter.... it's not reasonable IMO to be looking for that kind of power from pump gas anyway, if you can't afford race fuel to feed it you should lower your expectations and just deal with it.
