100 MM Mass Air ?
Old Feb 6, 2010 | 07:18 AM
cbluerock's Avatar
Default 100 MM Mass Air ?
Folks, can anyone recommend a 100MM Mass Air for my LQ9 408? I have a FAST LSXR 102 with LS7 throttle body and will be upgrading to 4" intake tubing and need a larger Mass Air than stock. Thanks
Old Feb 6, 2010 | 08:06 AM
vette0009's Avatar
http://www.lingenfelter.com/news/200...-intake-system
Old Feb 6, 2010 | 11:41 AM
TVWilkes's Avatar
TSP has one as well.
http://www.texas-speed.com/shop/item...d=914&catid=75
Old Feb 6, 2010 | 11:55 AM
99blancoSS's Avatar
The TSP piece is aluminum and can be polished to a very nice finish and is priced smartly.
Old Feb 6, 2010 | 08:15 PM
03 snake's Avatar
I'm running the tsp piece. Happy with the craftsmanship- I'm sure the lingenfelter is well made also.
Can't go wrong with either.
$.02
Old Feb 6, 2010 | 09:52 PM
SweetS10V8's Avatar
Ive used the Halltech 103.5mm, and the Lingenfelter 100mm. Both work as they should.
Your tube itself can be your MAF if you swap to a new LS3 MAF. Its a drop in piece when used with a GM mount. GM makes the "mount" out some kind of metal, havent seen one in person. I read somewhere the adaptor piece is under $10. Ive seen the MAFs new on ebay for $85
Old Feb 6, 2010 | 11:30 PM
SICKSS/Z28's Avatar
if your gonna run the 102mm tb id def get the 103mm
Old Feb 6, 2010 | 11:42 PM
PowerShift408's Avatar
Tuning the TSP MAF can be tricky as the IAT scales are totally different.
Old Feb 7, 2010 | 02:21 AM
hivoltagedriver's Avatar
SNL offers a really nice billet aluminum 100MAF housing that uses the LS7/ LS3? style MAF. I'm running one.
Old Feb 10, 2010 | 12:53 PM
5LTRETR97's Avatar
I have the Lingenfelter. Looks great and works well.
Old Feb 10, 2010 | 01:21 PM
TVWilkes's Avatar
This is the same as the TSP part.
Old Feb 10, 2010 | 01:23 PM
plumcrazy1's Avatar
This is the one that we used and worked out great.
http://www.powrmax.com/PowrMAF%20100.html
Old Feb 11, 2010 | 07:22 PM
WKMCD's Avatar
I run the same one on my build. Works great.
