im pulling my hair out
Old Feb 23, 2010 | 08:14 PM
the jester 812's Avatar
Default im pulling my hair out
ok i got my 408 built and installed and bolted to the trans. now the problems start.ok i went with a l92/l76 setup. but the l76 intake only has 1 fuel hookup and i have 2 lines coming up to meet it. my 2nd problem is finding a place to bolt my throttle cable bracket. i hear slp has a solution for that so i might just grab one of those. if i can get some help getting these things wrapped up i will move on to the other problems i have that i created for myself such a the ABS delete that i thought would be great to do while my car is down but ended up just adding to my stress.
Old Feb 24, 2010 | 07:37 AM
tektrans's Avatar
hehe, take it easy bro'.
The SLP bracket is simple and works well, I had it on my L76.
There is only 1 fuel line coming up, the other is some sort of vent or something if I'm not mistaken. There should be a hook up for it on you old intake, looks like a black plastic cylinder of sorts. Not sure what the function is but I had it hooked up with my L76.
What's the issue with the delete block for the abs? If it's a fitting issue, Burkhardt will help you with that through an exchange or at least some guidance.
Old Feb 24, 2010 | 11:08 AM
well what confuses me is the 2 fuel lines are coming up beside each other, and are wrapped together, do i just need to separate them, and find where the other goes on the l76
