Fast intake help
Old Apr 4, 2010 | 10:58 AM
Octavain's Avatar
Default Fast intake help
Completely new to 6.0L and bigger motors. Will a 92mm fast intake work on a 6.0L ls2 engine, LQ9, or L92? If not, why not? Thanks
Old Apr 4, 2010 | 11:09 AM
69LT1Bird's Avatar
The 92mm will work on the LS2, LQ9 cathedral port heads but not the L92/LS3, they get there own 102mm rectangle port style.
Old Apr 4, 2010 | 12:53 PM
Octavain's Avatar
And I would be dumb if I did not have L92 heads on my 6.0L build, correct? Or is there another set of heads that are equal to the l92 in performance, cfm, that have 92mm cathedral intake ports?
Old Apr 4, 2010 | 09:31 PM
SweetS10V8's Avatar
I went to CNC ported L92 heads myself on my 6.0L with a FAST LSXR 102mm. You can get the FAST 102mm for the cathedral port heads and L92 heads. The 92mm has been discontinued.
There are many cathedral port heads that flow really well(AFR,Trick Flow), they are just typically more expencive. But on the other hand they also have smaller cc runners,
