Tsp 402 short block
What else would i need for a gasket change !
Depends on what your doing with the 402 which should be 4 " bore and 4" stroke.
You need to calculate your comp ratio on what type of Pistons you are using and the chamber size of the heads !!
For street, I'd shoot for 11 to 1 or 11.5 to 1 !
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
