LS3 and L92 pictures needed
Old Apr 30, 2010 | 07:09 PM
tippy's Avatar
Default LS3 and L92 pictures needed
I've been looking around for pictures of the accessories on both these motors so I can map out what I need to change on mine. If anyone has pictures can you post them up?
thanks
Old May 1, 2010 | 01:31 PM
tippy's Avatar
So far I think the only issue is the drivers side, I do not need the power steering pump and the truck alternator position is to high, like to have it lower on the same side but have not found a good way to do it yet, anyone have any thoughts?
Old May 6, 2010 | 08:04 AM
BlownVette 2001's Avatar
Have you looked at the vette alternator brackets that sit lower.
Old May 13, 2010 | 04:13 PM
68Problemchild's Avatar
Default PICS of L92 changing into an LS3 with VVT
http://www.flickr.com/photos/41575483@N07/page2/
Just need to change the cam and springs now.
Old May 15, 2010 | 01:03 AM
ismdeuce's Avatar
Default LS3 alternator
[QUOTE=tippy;13267581]So far I think the only issue is the drivers side, I do not need the power steering pump and the truck alternator position is to high, like to have it lower on the same side but have not found a good way to do it yet, anyone have any thoughts?[/QUOTE The Cota Brothers did a LS3 conversion in a 63 nova. Go to steves nova site-forums-first generation nova-LS3 Larry. There are 35 photos of project. Some show alt and pulley views.
Old May 15, 2010 | 10:57 AM
tippy's Avatar
I decided to try S&P alternator bracket with the extra pulley setup as I do not have power steering. I will post pictures when I have it setup.
All in all my dealings with them were excellent, Mark really knew his ls3s and knew exactly what I needed to do to my 6l80e to make it 2wd AND had the part which is on backorder from GM.
Thumbs up from me.
Matt
