fast 102mm fuel injector / rail help
Old Jun 3, 2010 | 09:29 PM
1bigcam's Avatar
Default fast 102mm fuel injector / rail help
just got my fast 102 today and i put my ls2 stock rails and injectors on it, it dont seem like the injector fits down in the intake all the way. Anyone eles have this trouble? I just want to make sure it wont leak thanks mike
Old Jun 3, 2010 | 11:09 PM
RyanSws6's Avatar
Mine does the same thing. Runs good but I've yet to get it dyno tunned. I did buy the install kit.
Old Jun 3, 2010 | 11:51 PM
1bigcam's Avatar
whats the install kit do ??
Old Jun 3, 2010 | 11:54 PM
402GOAT's Avatar
If you use your stock rails injectors you need the spacer kit. Call comp tech service and they will know exectly what you need and you can order staight from the tech.
Old Jun 4, 2010 | 12:48 AM
djjonesivs's Avatar
you dont need a spacer kit if your running ls2 injectors and fuel rail.
you DO need a spacer kit if its ls3 fuel rail and injectors.
Old Jun 4, 2010 | 03:29 AM
402GOAT's Avatar
Been there done it ya need em but listen to whom ever you like
or get fast rails and injectors. They look beter anyways
Old Jun 4, 2010 | 06:58 AM
Aussie 6L's Avatar
I didn't like the spacer kit(the injector squirts at the spacer) so got some cnc custom made fuel rails. I'm in Aust so couldn't be bother waiting for FAST rails
This is a pic of spacer
Old Jun 4, 2010 | 07:18 AM
402GOAT's Avatar
Nice man.
Old Jun 4, 2010 | 11:35 AM
1bigcam's Avatar
found out what my problem was. the top shell of the intake was not seated in the lower part all the way, fixed that last night the injector fits down in the intake alot better now
Old Jun 4, 2010 | 06:55 PM
ramairws6's Avatar
Nice rails dude...........they are sweet!
Old Jun 8, 2010 | 06:33 PM
smok'nZ's Avatar
MASS seller approved
man i had a hard time gettingf mine to seat down but finally got it on there
Old Jun 8, 2010 | 07:59 PM
Unaffliated Racing's Avatar
This manifold was designed around the LS2 rails and injectors. No kit is need if using LS2 stuff. If you were to run a space on LS2 injectors, the rail wouldn't bolt flush.
Old Jun 8, 2010 | 10:54 PM
1bigcam's Avatar
the bolts that came with my intake for the rail are to long i had to use a thick washer under the bolt
Old Jun 8, 2010 | 11:30 PM
smok'nZ's Avatar
i used ls2 rails and stock style injectors
Old Jun 9, 2010 | 11:54 PM
dnkynrbk's Avatar
wow thanks for the info
Old Jun 13, 2010 | 08:49 PM
LT1Formula007's Avatar
OK! So I have a quick Question. And this may help out quite a few people here.
Which Fuel Rails and Injectors would I need to make the FAST 102/102 setup work on my engine? (403 LS2 Stroker with LS6 Heads)
I have a set of Delphi/Lucas 42 lb. injectors From Speed Inc. and a set of Nasty Performance Billet Fuel Rails now. They fit perfect on my FAST 92/92 setup, But I'm selling the 92/92 setup Wednesday to my brother. I don't want to sell the fuel rails unless I have to, But I wanna know if these will still work on the FAST 102 Intake! Will They still work on the FAST 102mm Intake? Or do I have to sell the Billet Fuel Rails and injectors. Or do I need the spacer kit?
Thanks
James
Old Jun 14, 2010 | 10:33 AM
Nasty N8's Avatar
The 92 intake was LS1 based and LS1 stuff will NOT fit on the FAST 102. I have new specific rails to fit the FAST 102 with short (LS3/7 style) inj. or tall (LS1/Bosch) inj.
Old Jun 14, 2010 | 01:55 PM
How much are the new rails for the FAST 102 setup? And are they polished, or are there different options?
Thanks
-James
Old Jun 14, 2010 | 02:17 PM
smok'nZ's Avatar
Thanks
-James
i have an ls2 fuel rail for 120 shipped
Old Jun 14, 2010 | 07:01 PM
Webbs's Avatar
I used the fast 146027 billet rails with 65lb fast ls3 injectors on my 102. I think the now sell oe style rails in a kit for the 102 as well.
