10 codes help!
Old Jun 6, 2010 | 01:12 PM
enraged350z's Avatar
Default 10 codes help!
Car went into safe mode last night while driving home. Started sputtering and then died and will not turn over at all now. Codes as follow.
P2101 0689 0449 0443 0340 0335 0102 2101 1682 0449
Im thinking power relay or ECM. Anyone know where to start on this one?
This prob is with my 2005 GTO M6 no major mods
Old Jun 10, 2010 | 11:39 AM
ShevrolayZ28's Avatar
Idk what all those codes are but 1st thing I'd do is check ur fuses. Good luck.
Old Jun 10, 2010 | 11:57 AM
intermediate skool's Avatar
DTC P2101 Control Module Throttle Actuator Position Performance
DTC P0689 Computers and Control Systems Ignition Relay Feedback Circuit Low Voltage
DTC P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit
DTC P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit
P0340 Camshaft Position Sensor Circuit Malfunction
P0335 Crankshaft Position Sensor Circuit Malfunction
P0102 MAF Sensor Circuit Low Frequency
P1682 Ignition 1 Switch Circuit 2 Malfunction
P0449 EVAP Vent Solenoid Control Circuit Malfunction
there the codes, sry bro, wish i could point you in the right direction but it would be hard to without actually working on the car
