Crank pulley fell off..............
Ok so I put a SLP UDP on my motor with a ARP crank bolt when I put the engine together, I torqued the pulley on with a old bolt to 240lbs and pulled the bolt off then put the ARP at 50lbs (calls for 37lbs). Well after 1k miles the bolt backed off and the pulley was walking off the crank. So last night I put a new stock bolt in it and torqued the pulley like I did last time. I go out for a drive and did a couple of WOT runs and the the pulley fell off. The bolt backed out and the pulley slipped off the crank. I looked at the bolt and the threads were fine so nothing stripped THANK GOD!
Anyways, I'm trying to figure out why my pulley keeps falling off? The pulley was new when I installed it the 1st time. I did noticed that it had a key cut out on it and when I bought the short block the crank was pinned in 3 or 4 different spots for a key.....I was told that was for supercharged applications and that a regular slp or stock UDP would work on it.
Do you think that putting a key on it will fix this problem? I can see a key helping slippage but will it keep the bolt from backing out? If not what would fix my problem? I thought about putting thread lock on it but that doesn't sound like a good idea to me...lol!
Any help would be good guys.......thanks!
http://www.ls1howto.com/index.php?article=23
Heres a cut and paste of the important part, You only did half of the required assembly hence your issues
NOTE: If you did not buy a longer crank bolt, and you are reinstalling the stock pulley, you run the risk of stripping out the first few threads of the crankshaft. This will NOT be fun to fix! Take your NEW crank pulley bolt and thread it in all the way by hand. Torque this bolt to 37lb/ft. Now, we need to stretch the bolt into place. Get your breaker bar and pipe extension, and try to turn the bolt 140degrees past where it is at now, keeping in mind the engine will be trying to turn some and those are degrees you can't count. Again, I always seem to get about 90-100 degrees worth (estimating, knowing what 90 degrees looks like) and leave it as is so don't worry about going crazy here.
Once the pulley is installed, the timing cover should be nice and centered around it, so we can now tighten all 10 of those timing cover bolts. Torque them to 18lb/ft on the bolts you can get a torque wrench on, and just make the others you can't get the wrench on about as tight as those. Reinstall the A/C belt at this time .
I guess I didn't do the 140* after I did 50lbs on the new bolt. I'll try that and I'll add a key in there just so the crank doesn't slip on the pulley. I'll also re-use the ARP bolt too.
I didn't think you had to torque and degree a ARP, but I wasn't sure. I have arp head bolts and they are just torqued. So you are saying that the ARP bolt needs to be torqued to 240lbs and left alone?
I believe ARP calls for 190 lb ft w/ their lubricant. Dry will require much higher values as you must overcome much more friction to achieve proper fastener stretch.You will not achieve proper tensioning without lubricant 99% of the time.
Screws/Bolts vs. Studs: When tightening a bolt you impart torsional stress into the fastener. A fair amount of effort put into tightening this fastener is in the form of torsional stress which will relax over time. When a nut is tightened on a stud there is no torsional stress involved as long as adequate lubricant is present.
C6 Batmobile: Use a longer lever and the recommended lubricant... It's not difficult at all with the proper tools. I use a 24" breaker bar attached to a craftsman torque meter and can achieve proper tension without issue.With the appropriate length lever a child could accomplish whatever value you like.
Just go buy a GM bolt...
