ls6 intake swap-parts needed??
Old Sep 28, 2010 | 08:05 PM
zaaronz's Avatar
Default ls6 intake swap-parts needed??
A knock sensor went bad on my car, so when i get them replaced i figured that would be the right time to swap to a ls6 intake. When looking for an intake im not sure all what i need. Some are selling with fuel rail, throttle bodies, injectors, and coolant crosover. Now i know my throttle body will bolt up to the ls6, and i dont need the injectors cause i read the 98's have the good ones- but do i need one with the coolant cross over?? thanks guys, just dont want to buy stuff i dont need
Old Sep 28, 2010 | 08:14 PM
demarco313's Avatar
Yes you need the coolant pipe and the 2 rear plugs. Here check out this link. Very informative!! Shows you what you need and how to install it..
http://www.ls1howto.com/index.php?article=5
you can purchase from here
http://www.c5racer.com/catalog/corve...gn=export_feed
You can also grind the ridges of the bottom of the intake to where you won't need these
Old Sep 29, 2010 | 03:31 PM
zaaronz's Avatar
thanks for the help- now i know exactly what to buy
Old Oct 1, 2010 | 04:54 PM
demarco313's Avatar
sure no problem anytime man!
