car wont run after fast 90 install??
so, put my fast 90 on today, everything went kinda smooth. had a little trouble getting the injectors back in, had alot of trouble with a vacume line(drivers side). but all in all not bad. however, when we went to start it up it just wouldnt run for very long. it will crank and run at 2500-3000 rpms for about 10-15 sec then spend another 5 dying. we have no fuel leaks at the rails or injectors, we bled the rails, but the car is parked on a slight incline so it seems like the passenger side cant get all the air out. the vacume line had to be... um... well, we made some **** up, but i cant see this being the problem, as the hole on the inside of the manifold is tiny. other than that, i got no clue as to what it could be. any help would be great guys as im in a huge bind here. just bought the wife a car a weeks ago and dont have enough money to **** away at a shop. ask me any questions you can, ill be on periodically all night till i get this figured out. thanks in advance guys.
