Another 2K idle thread...
Old Nov 28, 2010 | 11:02 PM
ries's Avatar
Default Another 2K idle thread...
Having issues with my cars idle and dont know what the problem is. Cold start my car idles fine between 800-900rpms. Once I drive the car and it gets to operating temp if I come to a stop the idle hangs anywhere from 1500-2000rpms. It doesnt matter what gear Ive come from, if Im in nuetral or in gear with the clutch pushed in.
Also seems like the cooler weather has made it more noticeable. If I shut the car off and restart it after its been at operating temp it will idle fine. What could my problem be? Vacuum leak? Bad sensor somewhere? Any help would be appreciated. Car is an '01 with a manual trans. Mods are in sig and car has been tuned.
Chris
Old Dec 26, 2010 | 08:55 PM
Mez's Avatar
Mez
Chris
The problem is with the minimum air table. Cut the air table 5% then see if it helps. Keep reducing it by 5% until it stops.
Old Dec 26, 2010 | 10:44 PM
Irish350's Avatar
I was gonna say Id take it to my tuner.. but that ^ is a lot more helpful; id imagine
