Are the fuel rails the same?
Old Dec 25, 2010 | 10:51 PM
jalper's Avatar
Restricted User
Default Are the fuel rails the same?
I have a ly6, and i want to rune the ls3 intake or the Truck intake, it is on a aftermarket EFI, so the injectors will not be a stock injector, My question is can I use a aftermarket ls1 fuel rail on a ls3.
basically what i am looking for is - are the spacing and the angle of the injector the same?
I know the mounting is different but i can fabricate all the small stuff, mostly concerned about the spacing from one injector to another and the angle that the injector sits at.
Old Dec 28, 2010 | 07:14 AM
Roar's Avatar
I'll let you know in a few hours.
I was wondering the same thing, but just received my LS3 intake and have a set of aftermarket fuels rails at home so I am going to check tonight.
Old Dec 28, 2010 | 07:41 AM
SweetS10V8's Avatar
Not without custom mounts. LS1 injectors are the longest, LS3 injectors are the shortest.
Old Dec 28, 2010 | 11:11 AM
Roar's Avatar
Spacing and angle is the same for the injectors, but rail mounting is in a different location.
No big deal, just need to make some custom brackets.
Old Dec 28, 2010 | 11:42 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
You will probably need a different bracket to mount the fuel rail. LS1 fuel rails will typically mount higher off the intake because of the taller injectors.
Old Dec 29, 2010 | 02:03 AM
jalper's Avatar
Restricted User
Thanks guys, I have a small 9x42 mill and a 16x60 lathe I will post what the brackets will look like middle of nest month.
