PROCOMP l92 heads.. anyone run them?
Old Dec 26, 2010 | 12:29 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
Default PROCOMP l92 heads.. anyone run them?
thinking about getting a set...
i need thicker decks so i can run more boost over the OEM heads...
i would like to get some info on them before i spend the change
THANKS!
Old Dec 26, 2010 | 03:48 PM
Mez's Avatar
Mez
THANKS!
Last month's Hot Rod did a comparison test with a 11 cathedral port heads on a 408ci. I think the ProComps heads made the most peak power and did well in other areas as well.
Just make sure you match the heads/cam/intake/headers to the engine size. Bigger is not necessarily better.
Old Dec 26, 2010 | 05:20 PM
do you have a link?
i'm more worried about 18-21psi with a 91mm turbo
Old Dec 26, 2010 | 08:49 PM
Mez's Avatar
Mez
do you have a link?
Line:
Hot Rod test of 11 cathedral port Cylinder Heads
Old Dec 26, 2010 | 10:45 PM
Irish350's Avatar
do you have a link?
lol maybe bigger is better...
Old Dec 27, 2010 | 08:03 AM
jdiddyws6's Avatar
I've got the GMHTP where they use them on their 417 stroker. They wanted them for compression drop and strength. Hit me up.
Old Dec 27, 2010 | 10:58 AM
Jimbo1367's Avatar
Once I got that issue, I looked at Procomps site and couldn't find any LS heads. Haven't tried since.
Old Dec 27, 2010 | 01:07 PM
LS3RX7's Avatar
The Pro Comp's have a 1/2" thick deck, stock is about .400" thick, so you would be gaining about .100" of extra material.
Old Dec 27, 2010 | 01:55 PM
commy's Avatar
would be good to know which head they copied as that is all pro comp does. Quality will be a issue like all their stuff.
Old Jan 1, 2011 | 12:49 AM
Jimbo1367's Avatar
Procomp seems to be tossing alot of their parts at magizine builds lately. I guess they are trying to get their name out there. They need to update their website to offer ALL products they supply to magizine builds.
Old Jan 1, 2011 | 05:47 PM
68 SS's Avatar
You get what you pay for...look at the LSA heads or the LS9 if you want a cheap alternative to the L92 that is still square port and has the bigger valves. I just bought a set of the LSA heads they are cast from a stronger material T356 and roto-cast much stronger head than the L92.
Just my .02
