Ls1,2,3,6,7??
Also in Bagram Afghanistan... The gen 3 and 4 engines are nearly identical, with 90% of parts interchanging. The Gen 4 engines used different sensor locations, and electronics.. If you're going to build an engine, I'd start with a 4" or larger bore block, instead of "punching out" an LS1 or LS6.. Keep researching, and look up engine build threads, and you'll learn alot in a short amount of time..
