thinking about going LQ9...looking for advice
From what I have been seeing is guys are making more than that through a cam only LQ9s with tons of room to grow...
I am looking for a low budget swap that won't cost me a fortune and make more power than my current setup...I know I can get a motor for around 2k.
also....Will my TH350 bolt up to the motor? also what size injectors do most guys run with them cam only? I have Bosch III 42lbs in my Car now that I would like to try and use if possible....
Thanks for any help..
Matt
The TH350 should bolt up no problem, the tq converter may need a spacer depending on the style.
I will be using the stock LS3 injectors on my cam only application and they should be more then sufficient.
