Do I need a new throttle body ??
Tom
hi,i believe you have an issue with carbon build up on the blade. if cleaning resolved the issue
and no other problems.the tb is probably ok from what you say. you can also remove tb and do a little very fine sanding with 1000-1500 grit paper.do not get over aggressive with your polishing. check the throttle blade often to avoid removing to much material. i hope this helps........have a blessed day.............jim
