L92 heads on LQ9
8 each L92 Intake Rockers
2 each L92 Rocker Arm Pedestals
L92 Heads.
Your intake will not work with L92 heads. You will need intake for rectangular heads, LS3/L76. Also, the L92 will work good with certain camshafts. I got custom cam from PG.
IMHO, you would be better off with LS1 heads like PRC from Texas Speed or Trickflows to work with your MS4 and FAST Intake and call it a day.
The only reason I went with L92 heads in my truck is to upgrade to L92 intake because I can't use car intake without major work. The L92 intake is choking the engine and I can't run the new FAST trucks intake because it is made for LS1 style heads and will not fit L92 heads.
L92 Heads.
They have the truck style 102 out for the Rect. port heads .
Well ****. i guess i lied. just checked thier website and i dont see it anymore. Guess they discontinued it.
You mean L92 intake?
