sensor swap?
Old Apr 15, 2011 | 02:12 PM
2000dreambird's Avatar
Default sensor swap?
hey guys im waiting for myu motor to show up im doing a LS3 swap in my 00 bird, my question is will i be able to just swap all my sensors over from the LS1 or should i get new ones for the LS3? also will the LS3 sensors plug in to my harness and operate right or should i just get new LS1 sensors and put them in the LS3,,,,,,,, any input would be greatly appreciated
Old Apr 18, 2011 | 03:06 PM
Anyone???
Old Apr 18, 2011 | 04:47 PM
TransWS6Am's Avatar
read this, it will answer all your LS3 swap questions. https://ls1tech.com/forums/generatio...02-f-body.html
In short, yes all your LS1 sensors will work, except for the cam sensor.
You have to swap reluctor wheels on the LS3 crank. Unless you ordered it with 24 tooth reluctor wheel.
You also will need a few extension : knock sensor, cam, and possibly MAP.
You will have to use an LS2 timing set and LS2 cam sensor.
You need a throttle cable bracket of some sort (unless your using a fast 102 manifold). the throttle bracket is cover in the above link.
I'm sure im missing a few things, but everything is covered in the link. If you have anymore questions after reading the link feel free to PM me.
Old Apr 18, 2011 | 10:22 PM
it will be coming with the 24x reluctor,and the LS2 conversion harness which includes the extensions ill need, a Nick Willams T.B. which is cable drive,
