First real mod (Speed daddy headers, flowmaster merge, cutout)
Old May 9, 2011 | 03:53 PM
QIK E's Avatar
Default First real mod (Speed daddy headers, flowmaster merge, cutout)
Alright I am about to pull the trigger on some ebay auctions, and I just wanted someone to look over my intended setup. This will be MY first mod to this car, and I'm pretty excited to get started. The car is a 00 SS t56 with a k&n and 3" magnaflow exhaust.....that's it
I plan on purchasing the flowing:
Speeddaddy EBay stainless headers
Y300350 flowmaster y collector
3.5" cutout
and then have an exhaust shop weld up the necessary piping (no cats)
Am I forgetting anything?
I don't think I will get 02 sims. I think i'll just get those codes tuned out along with egr and air......how long is advised to run like this without a tune?.....I am in alabama so no inspection and I don't mind the ses light
Old May 9, 2011 | 05:18 PM
S.O.MWS6's Avatar
you will need some O2 extensions for the front 2 O2's....don't forget about those. other than that, sounds good. oh and some gaskets for the headers.
Old May 9, 2011 | 05:56 PM
TransWS6Am's Avatar
https://ls1tech.com/forums/generatio...ong-forum.html
Old May 9, 2011 | 11:29 PM
QIK E's Avatar
Check and check. I think the gaskets are coming with the headers. Should I use better ones?
Old May 9, 2011 | 11:32 PM
QIK E's Avatar
Yea I figured this out a couple minutes after posting. I emailed a moderator but no response.
Old May 10, 2011 | 01:23 AM
BlueBird346's Avatar
If theyre the cheap paper gaskets, dont use them. Get a set of OEM MLS gaskets.
Old May 10, 2011 | 09:16 AM
QIK E's Avatar
They probably will be....i'll look in to those.
Starting a new thread in gen iii external cause I can't this one moved
