2008 LS3 Sensor Pinouts
Old May 31, 2011 | 02:17 PM
crash3's Avatar
Default 2008 LS3 Sensor Pinouts
I am using an aftermarket ECU on an LS3 and need some help with sensor pin outs.
I need:
Cam
Crank
MAP
Oil Press
DBW TB
DBW Pedal
Thanks.
Old Jun 1, 2011 | 07:40 AM
1A Dan's Avatar
I can help with the MAP:
LS3:
Pin 1 - 5 volts - gray
Pin 2 - Ground (low reference) - orange/black
Pin 3 - Signal to PCM - light green
now if someone just happened to have the LS1 version pinout, I'd be very happy (need to rewire my setup without burning my car down )
Old Jun 1, 2011 | 09:32 AM
crash3's Avatar
Thank you very much.
I have found the LS1 pinouts through various sources, including, IIRC, on this forum when I did a search. I didn't really log where it was because I am not focused on the earlier stuff, but you should be able to find it relatively easily.
Anybody else have any of the other ones?
Old Jun 8, 2011 | 01:27 PM
crash3's Avatar
The pinouts are available at www.myraceshop.com under the reference section.
http://myraceshop.com/Reference/GTM-...Pin%20Outs.pdf
