EVAP wiring
Old Jun 6, 2011 | 06:57 AM
sressue's Avatar
Default EVAP wiring
I have a GM performance LS3 with a EVAP purge solenoid on the engine. I also have a EVAP canister mounted near 2004 corvette fuel tanks. I also have a EVAP canister vent solenoid near the canister. The LS3 harness is wired to plug into the engine EVAP solenoid but I do not know were to connect the wires from the canister solenoid (purge vent). The wires are in the fuel tank harness. The two wires are pink and white. This is a Kit car using the LS3 with the 2004 fuel tanks. Can someone help?
Thanks.
