DBW( drive by wire) does not work
All connectors are hooked up.. I was told the rad fans had to be wired in to make it all work..They are and one even came on while car was idling.... The idling is rough cause I think the injectors are not opening properly..The motor has 10 k on it but sat for the last 5 years..............
I thibk if I can get some rpm on it it will help the injectors but I have ZERO response from the gas pedal and it is the original out of the car that all the stuff was pulled from... The pullout did NOT have the plug in wires for the gas pedal BUT the florida company said that is common and include a new one with there conversion...
Any ideas???????
Cheers
As a common problem w/ the J/Y injectors I do.
