cooling
Old Jun 20, 2011 | 03:17 PM
bam2589's Avatar
Default cooling
im having issues on keeping my engine temp down in this 100 degree heat any options.......i put a cam in my truck and it seemed to raise my temp there are no leaks the cooling system was pressure tested and it held a steady pressure for 45 minutes so any help would be much appriciated...........btw the truck is a 2003 chevy silverado with a 5.3 and has both e fans and stock c fan
Old Jun 20, 2011 | 03:20 PM
Schmalgar's Avatar
Do you have a tuner? You can adjust the temperature points for the fan, have it kick in sooner or just run all the time. That's probably the cheapest thing you can try first...
Old Jun 20, 2011 | 03:30 PM
bam2589's Avatar
i wired the fans into the o2 sensor fuse and did a piggy back fuse so it would all stay protected and the fans are off a 02 civic
Old Jun 20, 2011 | 03:33 PM
Schmalgar's Avatar
Lower temp thermostat?
Old Jun 20, 2011 | 03:38 PM
bam2589's Avatar
i cant find one for the type of water outlet that my wp has its the kind that is held by the outlet not just a drop in and bolt up
