Goal of 430rwhp - LS3 Setup vs 243 Setup ?
However, since you want to go with a mild cam for drivability, the LS3 top end would be my choice. There have been a lot of GTO guys getting really good results with relatively small cams. 430-450 should be no problem, and you could still add more later. You could always add a turbo setup if there was not blower option available. You will definitly want to upgrade that clutch and rear end though. Check out Monster Clutches and GeForce driveline components for that part.
Yes T56, the rear ends are way expensive for this car.... I think i will just stay away from beating on the car out of the hole....
